chuckmorr1s
Nov 05, 2018Aspirant
Looking at buying a XR500...
I currently have BT FTTP broadband 330mb up and 50mb down using the BT homehub 6.
I like the look of the geo filters on the XR500 and the network management tools to get the best connection for o...
pinkfloyd
Nov 05, 2018Tutor
I just returned my XR500, it has some great features but to be honest I dont have the time to try to find the right settings so I can play a game. I am not a big COD player but it seemed like after every game I would need to change settings so the next game would not lag or give me issues. I am a big BF player and since that game is really not supported, I just went back to my ASUS rt-3100. I have never had issues with this router since it came out and also with Merlin's FW, it works great. I wanted to try this router but I should have known better to trust NG products, I have always had issues with there stuff. I use the QOS bandwidth limiter 20 down 10 up on my ps4 and man I have no issues with lag, even on cod. I have at&t internet 1000 down 1000up, so I have more then enough bandwidth to go around.
I would say try the asus 3100 man you will like it in my opinion.
P111
Nov 06, 2018Luminary
I must confess I would not recommend it either. Thing is it just has too many bugs in it. Manual priorities can't be set. It doesn't recognise enough games. Mine just stopped working for no reason at all last night. I had to manually reset it. I mean my last router just worked for four years then this thing can't work for two weeks. Even at the best of times it's over-priced. I would certainly wait until they have some of the bugs out of it and the price has dropped a bit.
