Detanye
Mar 19, 2026Follower
Netgear XR1000v2 constant DNS issues
Hey all, As the title suggests i am having constant networking issues where i am unable to connect to any websites for several minutes that occur multiple times a day. I also have a forum going o...
Mar 19, 2026Guru - Experienced User
Detanye wrote:As the title suggests i am having constant networking issues where i am unable to connect to any websites for several minutes that occur multiple times a day.
Are your browsers set to use the OS DNS (which comes from the XR1000)? Or are they set to use DoH?
If they are using the OS DNS, you should try changing that and see if it makes any difference. If it doesn't, then that rules out DNS.
You might also try running some long-duration ping test, (pinging 8.8.8.8 ) and see if how often that fails to get a response.
