Djimi
Mar 17, 2018Guide
Netgear XR500 on Plusnet
Hello community, Please help. I've just set up my New Netgear XR500 on Plusnet. Seems to be working but cannot disable the WiFi on the Plusnet router so now have two devices giving out WiFi. Anyone...
Killhippie
Mar 17, 2018Prodigy
Thats a modem router again, which will need putting in bridge mode to work, should be fine though. Good luck.
Djimi
Mar 17, 2018Guide
Thanks buddy! Will keep you posted. Hopefully I can figure it out, if not will go for an out and out modem like the draytek 130.
