Mar 18, 2019Guru - Experienced User
New - XR700 v1.0.1.10 Firmware Available
New Features and Enhancements:
USB driver update to support Apple File System (APFS)
Login password enhancement
DHCP option 60 support for Internet configuration
Bug Fixes:
Improves s...
martyr444
Mar 21, 2019Apprentice
This firmware does make the GUI much slower to open no matter what browser you use when you compare it to the previous version. I did all the factory resets. You can simply go back to the previous and immediately see a considerable difference on how much faster it opens.
Shikwan68
Mar 23, 2019Star
Yes, I can confirm as well; the GUI is slower to load.....BUT ITS STABLE!!! I factory reset and have been monitoring it while gaming the last few days on Chrome, Firefox and Edge with no noticeable differences.
If they can keep the router stable AND speed up the GUI, in particular the Network Monitor apps (Network Overview & Network Snapshot) and the Geo Filter apps (Geo-Filter Map and Auto Ping. The GFM doesn't seem to work in real-time so much with Auto-Ping disabled as well btw.
Other than that - everything else seems to work great!
