Mar 18, 2019Guru - Experienced User
New - XR700 v1.0.1.10 Firmware Available
New Features and Enhancements:
USB driver update to support Apple File System (APFS)
Login password enhancement
DHCP option 60 support for Internet configuration
Bug Fixes:
Improves s...
TOOMUCHSAUCE
Sep 01, 2019Apprentice
1.0.1.18 does not fix the horrible UI. The UI works for a day or two then the QOS, Device Manager, and Network monitor tabs don't load (no matter how long you wait!!!) with an eventual message "The R-App has not loaded yet, please try again in a minute." Also, large chart in lower left of dashboard tab does not load. It's actually WORSE than the 1.0.1.10 release!!!
Unbelievable!!!
martyr444
I got the exact same results testing 1.0.1.18. "The R-App has not loaded yet, please try again in a minute." Also, large chart in lower left of dashboard tab does not load. It's actually WORSE than the 1.0.1.10 release!!!
Netgear/Netduma is a failure. I've never seem a Company take so long to provide a fix espeically for such and expensive piece of Hardware that is suppose to be their "Flagship". Look how long this has been out and no attempt to provide a working verified fix, this belongs in the "Hall of Shame".
- TOOMUCHSAUCESep 01, 2019Apprentice
They actually said they were aware of it and working on it back when many of us identified the issue with 1.0.1.10 release. In this thread there is mention of the team aware of the issues and working on it back on March 23rd!!! Here we are in September, 6 month later and they finally release a beta firmware with the SAME issue!!!
This router, and Netgear in particular, indeed belong in the Hall of Shame!!!
- Netduma-FraserSep 03, 2019NetDuma PartnerHave you tried the latest beta version?
- martyr444Sep 03, 2019Apprentice
The latest I tried was the v1.0.0.18 as posted.
- Netduma-FraserSep 03, 2019NetDuma PartnerTry the latest beta version and see if it improves at all
Isn't 1.0.1.18 the latest?
- Netduma-FraserSep 03, 2019NetDuma PartnerLatest should be .20, if it's not appearing on the beta forum check for an update on the router. If it's not there should be made available shortly.
I check for a new update on the Router daily, sill no .20.
- Netduma-FraserSep 03, 2019NetDuma PartnerShould be available soon then so please try that when available.
