m-corse
Jun 09, 2018Aspirant
Nighthawk XR500 configuration for IPTV
Hi everyone
I have spent the last few days trying to get an HT500a IPTV set top box working with my new XR500 router but I'm not having much luck. I have configured VLAN tagging with a tag grou...
Netduma-Fraser
Aug 16, 2018NetDuma Partner
Using VLAN and IGMP the issue still isn't resolved? I'd chase the ticket you have open
Ex0n
Aug 16, 2018Tutor
Yes please do, the last information was about me discribing witch ip goes to witch device.
Also my ISP's provide me the VLAN ID TAG 501, Prio 4.
Default for VLAN ID INTERNET 10, PRIO 0.
Witch should have worked.
My ISP's talked about that the
VLAN for internet needs to be untaged but thats impossible due to the XR500 are defaulted as taged in the VLAN tag. im not quite sure what they mean by untag when its already there as default.
However according to me, it shouldnt bee this hard to config an IPTV due to the steps are quite phew and very simple.
The IGMP was something to come up when i talked to my ISP even though they are not technician so they wasn't 100% how to use this and if it was needed for the router.
Rommel on netgear support is the contact man that esculated my case futher, now im not sure but it seems they are replying back to him and me.
Funniest thing was when i config the IPTV, my IPTV are going through and shows on the TV but then the internet shuts down. and my ISP can see that my IPTV is sending out an IP adress but not my internet. So it very clear that the package protocoll isnt working as it should.
And why are the internet shutting down its so weird.
Kind R.
Christian
- Netduma-FraserAug 16, 2018NetDuma PartnerI meant for you to chase the ticket, I don't work for Netgear so don't have access to their ticketing system.
- gamestonedOct 13, 2018Aspirant
Did you manage to solve this. I'm facing this on my brand new XR500. Configured IPTV on my Samsung MU8000 using SmartIPTV app but while swiping channels it takes anywhere between 10-15 secs & most of the time connection failed.
- Netduma_JackOct 13, 2018NetDuma Partner
(Just replied to your other thread with a suggestion btw)
