iamsotorious
Feb 20, 2019Aspirant
Nighthawk XR700 and AT&T Router IP Passthrough
Hello all.
I just recently switched to AT&T Fiber and i am using my router via ip passthrough. I have a small issue going on. When i connecto to the internet through my nighthawk XR700 i will g...
Netduma_Jack
Feb 22, 2019NetDuma Partner
- As Furry said, does your modem have bridge mode?
- Are you using the normal WAN port on the back of the XR700 to wire into the modem?
- Which firmware version are you on? You can find this by clicking the 'i' icon in the top right corner
iamsotorious
Feb 22, 2019Aspirant
The modem does not have a bridge mode feature. AT&T did help me setup the up pass through. The AT&T modem I do have is BGW210-700.
With all my test it it only Happens on the netgear I did get amazon to get me a return label thankfully.
