iamsotorious
Feb 20, 2019Aspirant
Nighthawk XR700 and AT&T Router IP Passthrough
Hello all.
I just recently switched to AT&T Fiber and i am using my router via ip passthrough. I have a small issue going on. When i connecto to the internet through my nighthawk XR700 i will g...
Netduma-Fraser
Feb 24, 2019NetDuma Partner
Not sure what you mean exactly, there are three versions available here: https://www.netgear.com/support/product/XR700.aspx#download
iamsotorious
Feb 24, 2019Aspirant
so after the downgrade it did get a lot better, the router still drops packets but not as significant as before, but the fact remains its still dropping out some how.
When previously before it would drop packet hard at the top and make a red line across all 3 and cause the hard stutter, this time it isnt hard stuttering and its only dropping at the router side.
Tomorrow i still have the rma for amazon im torn on what to do.
- FURRYe38Feb 25, 2019Guru - Experienced User
You might return the unit and hold off a while until NG gets this corrected. Then come back and try another one. Just keep an eye on the download site for updates.
- Netduma-FraserFeb 26, 2019NetDuma PartnerThat plot looks really good to me, the packet loss looks very minimal. If it's not actually causing you a network issue then I would say that's normal. Sometimes packet loss happens but it's not always bad. A service or program could send more packets than is needed to ensure it gets to its destination and therefore some may get dropped along the way.
- pinkfloydMar 07, 2019TutorHave you tried the dumb switch method? I also have att fiber, "only internet" not uverse! I dont use the att Gateway anymore, I by pass it and just use my Asus Rt-ac3100.
I'm here on theses forums because I was thinking of trying this router out again. But seems to me that it's still broken??? To bad. Seems like netgear never really got to fix it after all.
I might try it just to see if the dumb switch method would work and maybe not cause all the issues people are having with this thing.
Here is the link to the thread on dsl reports, all the info is on page 2 of the thread. I know the thread is not the model that you have, and believe me everybody who has att fiber wants the gw you have.
http://www.dslreports.com/forum/r32172124-AT-T-Fiber-5268AC-DMZ-to-Router-Speeds-50-200 - Netduma-FraserMar 09, 2019NetDuma PartnerWhat are the issues you're having pink?
- pinkfloydMar 11, 2019Tutor
I am not having any issues, I was replying to the OP.
- Netduma_JackMar 12, 2019NetDuma Partner
Ah good to hear, thanks for your help and for confirming.
