iamsotorious
Jan 14, 2019Aspirant
Nighthawk XR700 not getting full gigabit speeds
Hello.
I purchased a nighthawk righter earlier this month and i have not been able to achieve gigabit speeds.
attached screenshots show after multiple test.
I have updated firmware ...
Netduma_Jack
Jan 21, 2019NetDuma Partner
Two things to check:
Is your modem in bridge mode or modem mode when you're running these tests?
Have you fully disabled QoS? (In Anti-Bufferbloat advanced options)
If you've done both of these and you're not hitting GB speeds then I'm not sure what else the cause is, the XR700 can comfortably hit GB speeds ordinarlily so it's hard to know what else is preventing it from doing so here.
iamsotorious
Jan 21, 2019Aspirant
Arris sb8200 I don’t believe it’s in bridge mode but on that how do I check that setting I believe I googled it but never got a solid answer from it.
On the qos I disabled it from that section in the anti section what exact setting name am I looking for just Incase I am not doing it right.
- FURRYe38Jan 21, 2019Guru - Experienced User
The SB8200 is a modem only, no built in router so no support for bridging.
