modjoul105
Oct 11, 2018Aspirant
Not more than 30 devices able to connect
Hi,
I am trying to connect multiple (around 30) wearable smart-belts to the Nighthawk XR500 router but there is the loss of connection frequently. When I check the logs there seem to be a ...
Netduma-Fraser
Oct 11, 2018NetDuma Partner
If you give them static IPs does that resolve the issue?
modjoul105
Tried that. It didn't stop the ARP attacks from showing up when I connect the smart-belts.
- Netduma-FraserOct 11, 2018NetDuma PartnerDisable QoS completely from Anti-Bufferbloat settings and see if that resolves it please
