MRS911
Apr 16, 2020Guide
open ports on xr500
hello i want ask about open ports on xr500 for ps4 , i have bad experience with dmz :( so i want try to open ports but i dont know which setting i use .
Netduma-Fraser
Apr 29, 2020NetDuma Partner
Those settings look fine, have you changed the MTU? Did you test this to make sure you don't get fragmented packets?
MRS911
Apr 29, 2020Guide
i test mtu in letmecheck.it and i have maximum mtu size : 1492
so actully i dont know which mtu i choose ?? and i must change it in isp router and xr500 ?
and about traffic prioritization in QOS ,, Do i need to add ps4 console manually ?
