MRS911
Apr 16, 2020Guide
open ports on xr500
hello i want ask about open ports on xr500 for ps4 , i have bad experience with dmz :( so i want try to open ports but i dont know which setting i use .
Netduma-Fraser
Apr 29, 2020NetDuma Partner
I would recommend you leave it at the default 1500, changing MTU won't give you a better connection. As you have DumaOS Classified Games enabled you do not need to add it manually as it is already included in that option.
MRS911
Apr 29, 2020Guide
so i leave it on isp router and xr500 1500 mtu ?
