NiwaStanley
Jul 20, 2019Aspirant
Phillips Hue Bridge RED LIGHT on XR500
Hello, owner of the XR500 for 5 months now (Damn). I just bought Phillips hue bridge + bulbs from Prime Day (Weee $450~), I tried to connect the bridge to my phone but failed. I've read other posts t...
Jul 21, 2019Guru - Experienced User
Be sure the LAN cable is of good working quality between the router and this HUE device. CAT6 is recommeded.
Review the XR routers user manual for LED color indication behaviors.
IS the LED RED or more Amber, a dark orange color?
NiwaStanley
Jul 28, 2019Aspirant
According to the manual:
Solid amber. The router detected a 100 Mbps or 10 Mbps link with a powered-ondevice.
- -Donovan-Jul 28, 2019Luminary
NiwaStanley wrote:According to the manual:
It's normal and I have the same LED amber color on my XR700 because it's a 10/100 ethernet port on Philips Hue Bridge v2.0.
