Edward72
Feb 07, 2025Aspirant
Re: XR1000 Error "This Rapp is not loaded yet, please try again in a minute. "
 All,     After reviewing many suggestions, fixes, etc... from many different sites my DumaOS rapps still not loading at all.  not sure how to proceed.  Reinstalling firmware does not work either.    ...
- Feb 13, 2025I'd suggest reupgrading the firmware using the TFTP method, this bypasses the boot process and any issues there then once done do a factory reset for the freshest install possible: https://forum.netduma.com/topic/54949-dumaos-is-not-running/?do=findComment&comment=407569
Edward72
Feb 12, 2025Aspirant
the issue happens on Dashboard, GeoFilter, Ping Heatmap, Network Monitor, Device Manager, ADblocker, Connection Benchmark, traffic controller. Basically, almost all of them... Using different devices and/or browsers does not make any difference.
Netduma-Fraser
Feb 13, 2025NetDuma Partner
- Edward72Feb 14, 2025Aspirant
Thank you very much. All Rapps are back online.
 - Netduma-FraserFeb 14, 2025NetDuma PartnerGreat to hear that, thanks for the update!
