MeteorMike's avatar
Oct 29, 2019
Sending Myself Monitoring Logs
When I go to the SETTINGS-MONITORING-LOGS screen the choice SEND LOG returns a dialog box that says, "This site says... if you want to send an email notice, turn on email notifications in the email s...
  • MeteorMike's avatar
    Oct 29, 2019
    I went over and over the tabs and I finally found the email screen! It is under SETTING-CONTENT FILTERING-EMAIL. I guess I had just been looking at the screen too long! After finding the tab filling in the blanks was a breeze.
