Tola1303
Feb 21, 2023Tutor
This Rapp is not loaded yet, please try again in a minute
Mine isn’t working either. It keeps saying “This Rapp is not loaded yet, please try again in a minute.” I don’t know how to fix it.
Tola1303
Feb 22, 2023Tutor
It doesn’t load that either. It just has the loading circle nothing else. The only one that kind of works is the auto ping.
Netduma-Liam
Feb 23, 2023NetDuma Partner
If you reboot the XR, does Geo-filter then work again at least temporarily?
- Tola1303Feb 23, 2023Tutor
I’ve tried that and still nothing
- Netduma-LiamFeb 23, 2023NetDuma Partner
So it's just the map itself that's not loading and showing a spinning wheel? The auto-ping section is loading just fine?
- Tola1303Feb 23, 2023TutorThe map and the wheel do not load. Auto ping does load.
- Netduma-FraserFeb 23, 2023NetDuma PartnerCan you provide a screenshot of your entire screen of what you're seeing please?
- Netduma-FraserFeb 23, 2023NetDuma PartnerAre you using Armor by any chance? When did the issue first occur, after updating, changing settings etc?
- Tola1303Feb 23, 2023TutorI was using the armor but turned it off. I can’t give an exact moment it happened but I noticed it wasn’t working after I changed my settings. I also did a factory reset to see if that would work but to no avail. I changed the retries to five with armor off, still nothing.
- Netduma-FraserFeb 23, 2023NetDuma PartnerCould you downgrade to the previous version by uploading this firmware file: https://kb.netgear.com/000063915/XR1000-Firmware-Version-1-0-0-58 in Settings > Administration > Firmware Update and see if you get the same issue on that version please?
