bevant's avatar
bevant
Apprentice
Oct 18, 2020
UI issue but Netgear tech support is the dumbest in the world.... CONTINUATION
In the original post, I mentioned that in the XR500, if you plug a cable into port 4, in DumaOS, it shows up as Port 1.   Called Netgear stupid support and after THREE changes of modem, the problem...
  • Netduma-Fraser's avatar
    Oct 19, 2020
    .66 is just security updates from NG so no changes on our side. It's not fixed in the current build but the fastest way to get the fixes would be to upgrade to the 3.0 beta.
