usermac
Aug 03, 2018Luminary
Unable to install because some filters are overlapping.
 When you add a device the geo filter ask for the game. What I dont under stand is if I add the same device one that is set up for PUBG and then try to add the same device to work with Call Of Duty fo...
usermac
Aug 05, 2018Luminary
That would be great because at the moment the XR500 is not working all that well.
XRaptor29
Try going to device manager and select your PC and change the type to Xbox. Then remove your PC from Geo Filter and re-add as Xbox to the filter. Then change the setting to spectating instead of Filtered.
