JavelinSST71
Mar 04, 2026Aspirant
Unable to view/access XR1000 USB Storage in Windows Pro 11 File Explorer
Setting up a new Windows Pro 11 laptop. I want to use Windows File Explorer to view and access all folders/files within my WD External HD (connected to XR1000 through USB). Environment Details: ...
JavelinSST71
Correct - it worked on my previous Lenovo Windows Home 11 laptop with same router and USB drive and configuration.
This new Lenovo Windows Pro 11 laptop isn't recognizing the USB drive
No new security software enabled on this new laptop.
New laptop network settings are set for Private Network. I just watched a Netgear tutorial video on fixing Windows Pro 11 issues connecting to \\readyshare. The video was from 2015 - but tried the suggestion, and still not recognizing. I greatly appreciate you sticking with me on this - must be something simple I'm not catching.
Mar 04, 2026Guru - Experienced User
Be sure you enabled SMB v1.0 client thru this path: Control panel/programs and features/turn On or OFF Windows freatures. Looks for SMB Client v1.0. Apply and reboot the PC.
