DMC51450
Apr 10, 2019Star
UNSTABLE TICKRATE and lan problems
What's up !!! After months testing the XR500 i found an insane problem... auto ping shows you the tick rate of the lobby and yours... well... my XR500 is NOT ABLE to keep a stable tick rate of 150 ...
Netduma_Jack
Apr 15, 2019NetDuma Partner
Thanks, had a look through the images.
Honestly, not sure if there's anything to be worried about there. Send and receive rates fluctuate depending on what's happening within the game. For example, if you're near a lot of other players and a lot of action is happening, it will spike.
If you're having an inconsistent experience, I don't think it's because of this.
Are you finding the pings consistent across each game?
DMC51450
Apr 18, 2019Star
AH AH AH 😂😂😂 YOU SO FUNNY LIL JACK AH AH AH 😂😂😂 NO IT IS NOT NORMAL FLUCTUATIONS....IT IS DROPS SINCE IT DROPS BY HALF !!! WHAT ARE YOU TALKING ABOUT... NO THERE IS NO SPIKES OR CHANGE WHEN WE NEAR OTHER PEOPLES OR WHEN THERE IS BOMBS OR WHEN WE DIE ECT.... NEVER !!! YOU ONCE AGAIN PROOF THAT YOU DON'T KNOW WHAT YOU TALK ABOUT JACK AND THAT SUCKS... SO JUST BECAUSE OF YOU I MADE 3 VIDS THAT I'M UPLOADING ON YOUTUBE RIGHT NOW AND I'LL GIVE THE LINKS AS SOON AS THEY UPLOADED... YOU WILL LEARN !!!
