lushka
May 23, 2018Guide
VPN and Geolocation
Hey Guys,
Kinda new to this. Quick question. If I'm running a VPN connection via my router, is there a possibility to check my ping numbers for the lobby that I'm joining via the Geolocation R-app...
- May 23, 2018Hi lushka, with the VPN enabled the Geo-Filter will not work correctly. We're in the middle of testing our VPN Hybrid solution which may also resolve this issue depending on how it is used.
Netduma-Fraser
May 23, 2018NetDuma Partner
lushka
May 23, 2018Guide
Ok. Got it.
Thank you
