bacevedo
Oct 09, 2018NETGEAR Employee Retired
Wired vs Wireless: The answer may surprise you!
Wired vs Wireless.
The Debate.
This has been the debate of gamers since the beginning of wireless computing... and wired has traditionally won. Let’s take a couple minutes to exami...
schumaku
Mar 28, 2019Guru - Experienced User
"The XR500 has 4 ports each at 1 gigabit speed. It moves 2.6 Gb/per second wirelessly with a fantastic range. The XR700 has 8 ports, with the capability to go up to 10 Gb with an adapter on one port, allowing you to connect at incredible speeds wired. It also throws an insane 7.2 Gb/per second wirelessly. "
Both insane marketing lies.
This started with whoever started adding the maximum theoretical link rates of all radio interfaces.
802.11ad was and is brilliant for those having such a client and a direct line of sight to the router - for all others it's obsolete. People who understand wireless mentioned several times that Netgear should give much less marketing push to AD and the hype numbers. Does Netgerar have 0.1% of XR700 users actively using 802.11ad interface at all?
I just had to calm down an up set RAX120 test user who nagged that the performance is the same as for his old AC1900.
bacevedo
Mar 28, 2019NETGEAR Employee Retired
Don't take my word for it:
T3
https://www.t3.com/reviews/netgear-nighthawk-pro-gaming-xr500-router
IGN
https://www.ign.com/articles/2018/02/05/netgear-nighthawk-xr500-pro-gaming-router-review
PC Gamer
https://www.pcgamer.com/we-tried-netgears-first-gaming-router-and-its-the-fastest-weve-tested/
Tom's Guide:
https://www.tomsguide.com/us/netgear-nighthawk-xr500,review-5589.html
There's plenty of reviews to back up the performance.
- schumakuMar 28, 2019Guru - Experienced User
I don't deny the routers perform nicely and within the wireless standards reasonable fast, and have their market for both wired and wireless gaming and general users. All I'm complaining about is this faux marketing ref wireless (hype numbers, ways of reality) vs wired capabilities in the original post.
- bacevedoMar 28, 2019NETGEAR Employee Retired
I think you may have misinterpreted me. I will always say, if you can go wired. I play wired with my Xbox and PC. My Switch is wireless but it's mainly downloading games so it's not as crucial. Our position is to try to wire up your gaming devices and power eveything else in the house on wireless. They have great speeds for media, email, phones, smart devices...everything else you need to get internet to.
I hope this clarifies.
- schumakuMar 29, 2019Guru - Experienced User
No. I am just fighting against marketing lies. What you wrote in the original does contain at least two of these.
