GhillieK9
Apr 29, 2021Apprentice
Xfinity boosted my speed to 1.2gb, can I achieve that?
Hello, Xfinity just told me that my 1gb speed just got upgraded to 1.2. I have the XR700 router and the CM1100 modem. I see that my modem supports the WAN aggregation (hooking up the two ethernet...
- Apr 30, 2021
I don't see that the xr700 supports wan link aggregation but it does have the 10g port that can be used for wan.
But the CM1100 only has gigabit ports. It uses wan link aggregation for >1gig speeds.
So you can get faster spees that 1 gig with the xr700 but not with how the cm1100 connects to it.
Apr 30, 2021Guru - Experienced User
GhillieK9
Apr 30, 2021Apprentice
Okay thank you! I'll look into a different modem. Thank you all
- plemansApr 30, 2021Guru - Experienced User
Keep in mind the xr700's 10g port is a sfp port. Its not a standard ethernet connection so would need a sfp connector/adapter.
They're not exactly cheap.
- GhillieK9Apr 30, 2021ApprenticeDo you know much about the Motorola MB8611 DOCSIS 3.1? It has a 2.5gb port so looks like that would work for me...
don't know much about that device.
but again, look at the adapter needed to be able to connect the mb8611 to the sft port (amx765 adapter).
the netgear version costs around $300 (from netgear).
that's more than the cost of something like the RAX78 which support wan port aggregation and is a triband AX router.
Plus you have the cost of the mb8611.
Your costs are ballooning. Is it really worth the expense for the extra 0.2gig you'll get from your speed?
Especially when most devices/services can't even saturate gig speeds.
For example, streaming 4k tv only usually takes 30-40mbps max.
so you might see the benefit downoading a game (if the game servers are fast enough) or downloading massive files.
I've got the 1.2gig service from xfinity and the equipment to support it. But I haven't noticed a slight difference from 1gig to 1.2gig.
and I use a ton of data a month.
