polscifreak
Dec 15, 2022Guide
XR1000 2.4 Stops working
I bought an XR1000 a couple of years ago and haven't had any issues until recently. For about the last two months, the 2.4 band will stop working and nothing can connect to it. Rebooting the router...
polscifreak
Feb 16, 2023Guide
Sorry it took so long. It is currently happening. I haven't rebooted yet. My 2.4 is down. 5 works as well as wired.
Log is attached as pdf, as it well exceeds the limit.
Netduma-Liam
Feb 17, 2023NetDuma Partner
How far is the XR away from other devices that also use the 2.4 GHz band? For example, do you have a bridge or anything for your IoT devices near the XR? Is it nearby a Microwave or any other similar appliances for example?
- polscifreakFeb 17, 2023Guide
It's not too far. Definitely not far enough to be causing a problem. I don't have a bridge and it's not near a microwave or any such device that would be causing interference.
