Taurus2313
Jan 22, 2023Guide
XR1000 Connection issues-Again....
Hey guys...Well I am back again with the same issue I had about a month ago unfortunately. My previous thread on this issue (link below ->XR1000 Connection issues-Please help!) should be here in thi...
Netduma-Fraser
Jan 24, 2023NetDuma Partner
Would you mind providing a comparable SSID & Password that uses the same aspects as the details you're using please? That would allow us to try and reproduce the issue.
E.g. If your SSID is TaUruS2023=2.4G then give us FrAseR2023=2.4G
Taurus2313
Jan 24, 2023Guide
In my previous thread I did provide you an example in message/reply 6 of 14..
2.4ghz SSID example: Captainkangaroo2
First letter is capitalized the rest all lower case with one number on the end.
2.4ghz SSID PW example: Michael846
Same as above.. First letter capitalized then lower case letters followed by numbers on the end.
No special characters are used. This is the way that this 2.4ghz SSID and PW has been for 2 years without issue until now..
- Netduma-FraserJan 24, 2023NetDuma PartnerI just wanted to be sure because it is very standard, could you provide a screenshot of the Advanced WiFi settings please?
- Taurus2313Jan 25, 2023Guide
I am assuming that this is what you are asking for?
Settings
- Netduma-LiamJan 25, 2023NetDuma Partner
Sorry, we can't see that screenshot as it's not been moderated yet. Could you try attaching it instead, rather than pasting it in?
