Taurus2313
Jan 22, 2023Guide
XR1000 Connection issues-Again....
Hey guys...Well I am back again with the same issue I had about a month ago unfortunately. My previous thread on this issue (link below ->XR1000 Connection issues-Please help!) should be here in thi...
Jan 27, 2023Guru - Experienced User
If you do a reset and setup from scratch and use just the default SSID name and PW, does this allow for a device to connect?
Beginning to think this unit is faulty some how.
Any chance you can find a 2nd XR1000 on Amazon to try out?
Taurus2313
Jan 27, 2023Guide
FURRYe38 YES... I thought that I did make that clear in all my posts. Sorry if I did not.
Also I mentioned that I have purchased another router and it arrived yesterday but I have not had a chance to connect it to my modem yet. It is not a Netgear product so I am going to see if I have any issues with using the same SSID and PW on that device. I think that will settle what is going on. I will come back here to update after.
- FURRYe38Jan 27, 2023Guru - Experienced User
Send me in a PM your exact SSID name and PW and I'll try it out on mine to confirm on this if the example is not exact in your last post.
I have seen some odd SSID and PW configurations issues but on on the XR series products.
