BIGRIFF
Jan 30, 2026Aspirant
XR1000 dropping out every couple of hours
Im getting the same issue and i dont know what to do to fix it. I have reserved all my devices from .2 to .49 and set the DHCP range from .50 to .99 and yet im still experiencing a dropout which d...
BIGRIFF
Feb 02, 2026Aspirant
Well it disconnecting me also causes the 'connection benchmark' utility to fail. I really do not think that is the way it is supposed to work. System Information Page shows the correct time of GMT.
with it also crashing when I do a speed test on Ookla makes me believe the unit cannot handle the processing of the speed test.
Netduma-Fraser
Feb 02, 2026NetDuma Partner
What settings have you changed from their defaults? Particularly in settings?
