Edward72
Feb 07, 2025Aspirant
Re: XR1000 Error "This Rapp is not loaded yet, please try again in a minute. "
All, After reviewing many suggestions, fixes, etc... from many different sites my DumaOS rapps still not loading at all. not sure how to proceed. Reinstalling firmware does not work either. ...
- Feb 13, 2025I'd suggest reupgrading the firmware using the TFTP method, this bypasses the boot process and any issues there then once done do a factory reset for the freshest install possible: https://forum.netduma.com/topic/54949-dumaos-is-not-running/?do=findComment&comment=407569
Netduma-Fraser
Feb 07, 2025NetDuma Partner
Could you let us know what you have attempted to do to fix it please and what firmware version you're on?
Edward72
Thanks for the help.
So far I have, rebooted, restarted, reset to defaults, updated/rolled back firmware, removed power and waited for 10+ minutes, confirmed it is in the list of Installed Apps and set to run at start up.
Current version is XR1000 1.0.0.74_1.0.63
- Netduma-FraserFeb 08, 2025NetDuma PartnerGo to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, wait 4 minutes before accessing and see if it works then please.
- Edward72Feb 08, 2025Aspirant
The value is set to 5 and router rebooted. Still the same symptoms with other rApps as well.
- Netduma-FraserFeb 08, 2025NetDuma PartnerYou do have some access otherwise you wouldn't have been able to do some of these things, is this something you're seeing on a specific page, if so which one, otherwise how often is it occurring that it prevents proper access?
