Edward72
Feb 07, 2025Aspirant
Re: XR1000 Error "This Rapp is not loaded yet, please try again in a minute. "
All, After reviewing many suggestions, fixes, etc... from many different sites my DumaOS rapps still not loading at all. not sure how to proceed. Reinstalling firmware does not work either. ...
- Feb 13, 2025I'd suggest reupgrading the firmware using the TFTP method, this bypasses the boot process and any issues there then once done do a factory reset for the freshest install possible: https://forum.netduma.com/topic/54949-dumaos-is-not-running/?do=findComment&comment=407569
Edward72
Thanks for the help.
So far I have, rebooted, restarted, reset to defaults, updated/rolled back firmware, removed power and waited for 10+ minutes, confirmed it is in the list of Installed Apps and set to run at start up.
Current version is XR1000 1.0.0.74_1.0.63
Netduma-Fraser
Feb 08, 2025NetDuma Partner
Go to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, wait 4 minutes before accessing and see if it works then please.
- Edward72Feb 08, 2025Aspirant
The value is set to 5 and router rebooted. Still the same symptoms with other rApps as well.
- Netduma-FraserFeb 08, 2025NetDuma PartnerYou do have some access otherwise you wouldn't have been able to do some of these things, is this something you're seeing on a specific page, if so which one, otherwise how often is it occurring that it prevents proper access?
- Edward72Feb 12, 2025Aspirant
the issue happens on Dashboard, GeoFilter, Ping Heatmap, Network Monitor, Device Manager, ADblocker, Connection Benchmark, traffic controller. Basically, almost all of them... Using different devices and/or browsers does not make any difference.
