Rolex
Nov 13, 2021Tutor
XR1000 GeoFilter "The Rapp is not loaded yet, please try again in a minute" on DumaOS
I have been trying to use GeoFilter on my newly purchased XR1000 router through DumaOS and it will not open. Firmware version 1.0.0.58 Any suggestions would be appreciated.
Netduma-Fraser
Nov 23, 2021NetDuma Partner
Probably the best thing to do here would be to reupgrade the firmware using TFTP - this bypasses the boot process and any issues there, then once complete do a factory reset. I know its a hassle but it will be the freshest install possible as the firmware may have been corrupted when updated to originally. Once a reset is done wait 2 minutes before accessing the router.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP?article=000059634
Goletto13
Jan 01, 2022Aspirant
Just wanted to confirm this was the process to fix the issues discussed here, the same issues i have been experienceing for the last 2 days.
It is a nightmare of a process but it did work.
To be clear I purchased a new Netgear Nighthawk XR1000 gaming router and found that even after a proper installation and setup the geo filter and ping heatmap did not show up at all.
I followed previous steps to reboot, reset, and reinstall the current firmware. None of which solved this issue.
However following this process did work.
Good Luck
- ShadeauxJan 01, 2022Star
No, I uploaded a config through the router admin pages once to older firmware that I downloaded, but that didn't resolve it.
I didn't do the process on that link with the DOS command prompt.
Another quirk people should be aware of is if you are using, say, Edge Browser to access router page for setup, but your DEFAULT Browser is, say, Google Chrome, then at points during install, Edge opens next step in Chrome, instead of Edge Browser you were using... and having the 2 browsers trying to access same pages causes issues.
So, use default browser to setup.
