DKE350Z
Jan 26, 2025Tutor
XR1000 Spotify tracks pause before playing next track
I've had a strange problem with my XR1000 router and Spotify. There's a bit involved, so I'll start with the symptoms. When I use Spotify Connect, to stream music to my Anthom MRX1140 receiver, ever...
- Jan 30, 2025That's interesting, well done for determining that, it could be QoS, if you disable this fully from the Congestion Control menu does it still occur?
DKE350Z
Jan 29, 2025Tutor
I just tried Amazon music, and this works fine.
It is different however, as using Amazon Music shows as "Casting" input on the receiver whereas Spotify shows as "Spotify Connect." Once started with my phone, Spotify Connect can continue playing a playlist on the receiver independently, unlike streaming.
So combination of Anthem, Spotify Connect and XR1000 don't work together.
Netduma-Fraser
Jan 30, 2025NetDuma Partner
