DiscreetLee
Jun 15, 2022Follower
XR1000 won’t load Geo Filter or Ping Heatmap
I’ve tried everything. I’ve tried rolling back updates then updating to the newest firmware, I’ve tried using edge, I’ve tried disabling armor, I’ve tried resetting. I just don’t know what else to do ...
Netduma-Fraser
Jul 17, 2022NetDuma Partner
Okay try a factory reset then please, again wait 2 minutes before you access, also when going through setup don't enable Armor
louie0827
Sep 05, 2022Aspirant
rebooted router, geo filter wont work on PC macbook anymore, tried a couple more reboots still same message.
- Netduma-LiamSep 05, 2022NetDuma Partner
Could you please clear your browser's cache/try accessing the interface from an incognito/private window? See if Geo-filter can then load properly after that.
