zeth07
Jul 05, 2026Aspirant
xr1000v2 - network spikes higher shown than real usage?
xr1000v2 1.1.0.22_2.1.34 While I'm monitoring my network to see what is causing lag spikes, I've seen that the "Network Overview" is showing spikes much higher than what ANY DEVICE is showing in ...
- Jul 05, 2026
Not sure how all that maybe calculated. May depend on actual data flow between the device and router and what router is actually seeing.
Your FW is behind, might update it and check to see if anything changes.
Jul 05, 2026Guru - Experienced User
- zeth07Jul 05, 2026Aspirant
Thank you, I'll look into updating the firmware later when I have some downtime.
