GreggIrvin
Nov 17, 2024Aspirant
XR1000v2 router not working with Paramount Plus application
 I recently purchased an XR1000v2 router to replace a 10 year old Netgear router that was still working fine except that it suddenly stopped letting me access an email server.  I installed the XR1000v...
- Nov 17, 2024Disable the Adblocker on the router, does it work then?
Netduma-Fraser
Nov 17, 2024NetDuma Partner
- GreggIrvinNov 18, 2024Aspirant
Disabling the adblocker appears to have solved the issue. Thank you so much!
- Netduma-FraserNov 18, 2024NetDuma PartnerGreat to hear that, thanks for the update! You can leave it disabled or manually allow the URLs for paramount and then re-enable Adblocker and it should stop blocking it then.
