Osiris_Black
Apr 30, 2018Star
XR500 & Xbox One X
 Hi Everyone,
 I have a CM1000 connected to a XR500. My XR500 connects directly to my Xbox One X, Hardwired with IPV6, QoS, and UPNP activated, and connected to my PS4 wired as well. Everything e...
- Sep 08, 2018
NETGEAR have publicly released the firmware that fixes disconnection issues.
If anyone is still having this issue, please ensure you have upgraded to the latest firmware (2.3.2.32 or later): https://www.netgear.com/support/product/XR500.aspx#download
XRaptor29
Sep 07, 2018Luminary
Latest Alpha build to Xbox has this in the fixes
System:
Fixes to the stability of the console going in and out of the Instant On power mode.
Looks like Xbox has figured out the problem hopefully.
System:
- B1ggSh00t3rSep 07, 2018Apprentice
System:
Looks like Xbox has figured out the problem hopefully.I have the latest Alpha Build for Xbox One X. I've had NO issues w/ disconnects and Instant On power mode.
- Netduma_JackSep 08, 2018NetDuma Partner
- NupeEsqSep 28, 2018Tutor
This thread has been very helpful. Unforutnately, neither the new Netgear firmware nor the latest Xbox firmware has addressed the issue. I'm having the same problem. Connected via LAN things work fine; then I turn it off into Instant On mode, and when you wake it up, Xbox says it can't connect. Moreover, the router says its disconnected in the Device Manger tab on DumaOS. Hope there is a fix for this soon. Does anyone have any advice? Thanks!
