Netduma-Fraser
Sep 10, 2019NetDuma Partner
Re: XR500 and CM1150V modem randomly disconnects everything wired and wireless.
I've moved this topic to the correct forum. What firmware is the XR500 using? When did this start happening? What is your exact physical setup? e.g. CM1150V > XR500 > all devices
OmgItsPaco
Sep 08, 2019Tutor
Hi I have a CM1150V connected striaght into a RX500. I randomly get disconnects but the thing is my router and modem status lights shows it still connected to the internet. Every device is disconnected including my hardwired PS4 and PC and my Wireless Iphone X. The only way to get back online is to unplug and plug back in modem and router. I need consistency its very important for me since I play online tournaments and Stream on Twitch.
Netduma_Alex
Sep 11, 2019NetDuma Partner
In the CM1150V, is there a DMZ option?
Also that screenshot you sent is so small that I can't read it. Could you send a bigger version? You could attach it, or you could send a dropbox/wetransfer link.
- FURRYe38Sep 11, 2019Guru - Experienced User
The CM1150v is a modem only with phone support. There is not router built in thus no DMZ.
- Netduma_AlexSep 11, 2019NetDuma Partner
Ooh right, didn't know that, thanks.
I don't know much Netgear hardware beyond the Nighthawk Pro Gaming series :smileyembarrassed:
- OmgItsPacoSep 14, 2019Tutor
I'm not sure if this screenshot is bigger or not for you. If not could you please tell me how to make it bigger
