Netduma-Fraser
Sep 10, 2019NetDuma Partner
Re: XR500 and CM1150V modem randomly disconnects everything wired and wireless.
I've moved this topic to the correct forum. What firmware is the XR500 using? When did this start happening? What is your exact physical setup? e.g. CM1150V > XR500 > all devices
Netduma_Alex
Sep 11, 2019NetDuma Partner
In the CM1150V, is there a DMZ option?
Also that screenshot you sent is so small that I can't read it. Could you send a bigger version? You could attach it, or you could send a dropbox/wetransfer link.
Sep 11, 2019Guru - Experienced User
The CM1150v is a modem only with phone support. There is not router built in thus no DMZ.
- Netduma_AlexSep 11, 2019NetDuma Partner
Ooh right, didn't know that, thanks.
I don't know much Netgear hardware beyond the Nighthawk Pro Gaming series :smileyembarrassed:
- OmgItsPacoSep 14, 2019Tutor
I'm not sure if this screenshot is bigger or not for you. If not could you please tell me how to make it bigger
- Netduma-FraserSep 14, 2019NetDuma PartnerWhat firmware is the XR500 using? When did this start happening? What is your exact physical setup? e.g. CM1150V > XR500 > all devices
The picture is too blurry even when enlarged, take an actual screenshot rather than a picture with a phone and it'll be fine.
