Netduma-Fraser
Sep 10, 2019NetDuma Partner
Re: XR500 and CM1150V modem randomly disconnects everything wired and wireless.
I've moved this topic to the correct forum. What firmware is the XR500 using? When did this start happening? What is your exact physical setup? e.g. CM1150V > XR500 > all devices
Taz71
Jan 06, 2020Aspirant
Did you get the wifi issue resolved? I recently purchased the CM1150V and have the XR500 router and now my wifi devices are not connected. I hope there is a fix to this problem.
Your help is appreciated.
Netduma-Fraser
Jan 07, 2020NetDuma Partner
What do you mean they're not connected exactly? Can you see the WiFi in your devices WiFi list?
