Raf1212
Jun 08, 2020Apprentice
xr500 beta DUMAOS 3.0
hello everyone, I have a question where the beta version 3.0, the big announcement was 02.06, still nothing, a week passed, many people are waiting for it because xr500 is not working well, it is ver...
generozen
Aug 09, 2020Tutor
Hi,
How do you get the Xr500 to show devices in the IOS Nighthawk app? It has never worked for me on any firmware versions including the latet 3.0.
I Router was was reset to factory multiple times with same results.
It just says "Sorry, the action was failed. Please try again. .
twistof8
Aug 10, 2020Aspirant
It only works for me when I use it in Remote mode. You ha e to be connected to the same wifi to enable remote mode, then disconnect from wifi and connect as remote using cellular data. Hopefully it works for you too.
