Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
Netduma-Fraser
Oct 18, 2018NetDuma Partner
Hi all, for those still experiencing this issue post here and we will PM you. We have a beta firmware available which should hopefully fix the issue. Danny, I'll send it to you now.
smitheram
Oct 18, 2018Guide
Hello,
I have recently purchased the Nighthawk Pro XR500 which has the most recent firmware installed. Would it be possible for you to PM me the beta firmware mentioned?
Best Regards,
Shane
- Netduma-FraserOct 18, 2018NetDuma PartnerSent you a PM Smitheram
- Danny80916Oct 18, 2018Luminary
Thank you just installed update , I figured out what was causing all my remote lan access logs. My ps4 was in dmz so it was logging a bunch of Remote access logs.
