Billybudz420
May 02, 2018Apprentice
XR500 drops internet
I am having an issue where the internet stops working..... I have 2 Xbox ones being used and they randomly disconnect and now the wifi doesn't work either. The wifi is connected but no internet. On...
- Sep 08, 2018
The firmware has now been publicly released: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/New-Firmware-for-XR500-2-3-2-32-fixes-disconnection-issue/m-p/1636839#M3864
If you are having a disconnection issue, please upgrade to this firmware (or a later one in the future). Thank you everyone for your patience
chaosminionx
Dec 03, 2018Aspirant
Could I also get the firmware PM'd to me? Thank you!
smitheram
Dec 03, 2018Guide
Is the hotfix more recent than beta 2.3.2.3280231009?
- Netduma_JackDec 03, 2018NetDuma Partner
- T-Morgan-911Dec 03, 2018Aspirant
Can I please get the fix as well
- Danny80916Dec 04, 2018Luminary
I would like the hotfix also.
- Bulldaw6Dec 11, 2018GuideHelp, have instant on off. No internet wired or wireless. Did 3 reboots, no internet. Bypassed the router and have internet :(
- Netduma-FraserDec 11, 2018NetDuma PartnerDo a factory reset using the button in the back of the router. Hold for 30 seconds and let go, then connect to interface and go through the setup wizard. Are you on the beta firmware?
