Robh19
Jan 17, 2019Aspirant
XR500 Hardwire console procedure
I set my router up last night, but i can’t figure out how to run it with a wired connection to my consoles. Called tech support today and was told that I had to pay an additional $159.99 to download a...
Jan 17, 2019Guru - Experienced User
game consoles?
Just connect a CAT6 LAN cable between the router and the game consoles.
Robh19
I did that to start. The system recognizes it, but the router doesn’t. System says it’s hardwired, but I can’t connect to the online gaming. Also, it doesn’t recognize it in DumaOS.
- Netduma-FraserJan 18, 2019NetDuma PartnerAre you referring to the Device Manager? It may not have detected what it was but should still appear, just may need to rename the device. Match the IP/MAC address shown on the Device Manager with the console network settings. Are you using the Geo-Filter?
- Robh19Jan 18, 2019AspirantYes, I’m using the geo filter.
- FURRYe38Jan 18, 2019Guru - Experienced User
What FW is currently loaded?
Robh19 wrote:
I did that to start. The system recognizes it, but the router doesn’t. System says it’s hardwired, but I can’t connect to the online gaming. Also, it doesn’t recognize it in DumaOS.- Netduma_JackJan 21, 2019NetDuma Partner
Do you have static IP addresses on your consoles? If so, you should disable these and allow it to dynamically receive an IP address from your router.
If that's not the solution, what happens when you run a network test on your console? You said it will not connect, so what error message do you see?
