madnz
Sep 14, 2020Tutor
XR500 LAN Connectivity Issues
So In October 2019 I had recently purchased a new XR500. I did the set up as per normal and everything seemed to work normally, However it seems I have had some connectivity issues connecting to my S...
Netduma-Fraser
Dec 21, 2020NetDuma Partner
I'm really not sure what else I can suggest to be honest, there aren't any other settings that I could see affecting this. You said it happened after changing routers, could you place the XR behind another router but put it in AP mode please and connect to the XR via wifi and see if it works?
I'm not suggesting to keep it that way the whole time but that will essentially disable DumaOS entirely so if it's a DumaOS issue it should work, if it isn't then it won't and I'll know who to pass it on to.
GoalTV
Jan 02, 2021Aspirant
Hey
Anyone has found any soltution i'm running to exact same issue on my XR500
On Wired local devices loads fine on wifi it takes 10 Minutes to load a simple interface via local network.
I tired disable everything, looks like there is some kind of firewall in dumaos which we don't have access to due poor UI options.
Maybe if we could stop services manually to debug it would be better solution I also have tired upgrade to 3.0 to see if it fixed.
I did over 10 Factory Resets and issue is still there. so looks like it's some firewall which is blocking the wifi connection with wan. as it seems to work for few sec on router boot until services are loaded which we can't disable.
- GoalTVJan 02, 2021Aspirant
Also forgot to mention I noticed the issue only exists on IPv4 Local if you try IPv6 Local it works fine
- Netduma-FraserJan 02, 2021NetDuma PartnerI'll respond to your topic over on the Netduma forum GoalTV
- JoseExpositoJun 28, 2021Aspirant
Yo tambien tengo este mismo problema, ¿alguna solución?
- Netduma-FraserJun 28, 2021NetDuma PartnerTe he respondido en el foro de Netduma
- madnzJun 30, 2021Tutor
No Solution, even on the beta.. Absolutle waste of money this router.. went back to my old netgear router and performs better even though its 8 years old..
- Netduma-FraserJun 30, 2021NetDuma Partnermadnz sorry to hear that, Netgear have collected all the information they need from other users experiencing it so it shouldn't be long before they have a fix
- madnzAug 28, 2021Tutor
2 Years Later.. Still no fix..
