P111
Nov 06, 2018Luminary
XR500 Lockup. ( disconnect? )
OK for the first time the router died. It's been running continuously for maybe a week. I came to it in the morning and it was dead. Funny thing is that the wireless was even switched off. It was onl...
Nov 06, 2018Guru - Experienced User
What is the model# of this modem?
What is the model# of the NG switch?
I would try and power OFF both modem and XR router for 1 minute. Then power ON the modem and let it sync. Then power ON the XR router.
Are you letting the XR handle the PPPoE connection or is the modem handling this?
P111
The modem is a Draytek 130.
The switch is a Netgear GS108 ( latest type ).
I didnt need to reset the Draytek or the GS108 this morning, it was just the XR500 that had locked up. Unfortunately I didn't check the wifi or the PC that had been on all night. I just checked my main PC which had been off all night. It came on as usually but no internet and no XR500. I reset the PC several times before I reset the XR500.
I don't let anything handle anything. It did it itself. However, the XR500 has the configuration in it for PPPoE and the username and password so I assume it's the XR500 thats handling it. The modem doesn't have any settings like that.
It is a bit suspicious to me that XR500 crashed during a period of long inactivity. It's the only time the PC has been left on all night but not actually doing anything. Normally it's either off or on and running applications that access the net.
- FURRYe38Nov 06, 2018Guru - Experienced User
Thre maybe possible issue with the XR handling PPPoE if you have your modem bridged:
https://www.draytek.co.uk/products/business/vigor-130
Something you can try to see if the XR continues to hang. Set the modem back to Un-Bridged mode and let the modem handle the PPPoE connection. Set the XR back to Dynamic or DHCP on the WAN port. Set up an IP address reservation ON the modem for what it gives the XR router. Input this IP address into the modems DMZ. Save settings and then I would power OFF the modem and XR for 1 minute, then power ON the modem and let it sync, then power ON the XR router.
See if the XR router continues to hang. If so, then I would get the XR replaced or contact NG support and let them know whats going on with the XR router.
- P111Nov 06, 2018Luminary
As far as I am aware its not a router. It actually states its not in the manual. And certainly I set nothing when I was using it. It's not set in bridge mode becuase it's always in bridge mode.
But why would this cause the XR to hang anyway? I mean it was running perfectly for 14 days then bam, gone. What suddenly changed?
Well the modem can be un-bridged I believe and handle the PPPoE connection instead of being in bridge mode. Something to try. A reason to try this is to see if the XR router does this in DCHP mode vs PPPoE.
Where is the XR placed? Does it have good air ventilation? I keep a laptop cooler under my router all the time for added cooling.
What channel modes are you using? Auto or manual?
Any other wifi neighbors around? Of so, how many?
