waver123
Apr 06, 2021Aspirant
xr500 losing settings on reboot
Hi all, Probably couple weeks ago I'd some internet issue and at that time power cycled my xr500, after that the router seems cannot hold the setting on reboot (through gui interface). Whenever I t...
Netduma-Fraser
Apr 17, 2021NetDuma Partner
I'd suggest you upgrade to the 3.0 beta and use the TFTP method to do so which will bypass the boot process and any issues there https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP then factory reset after and see if it works
waver123
Apr 18, 2021Aspirant
I installed the latest beta firmware (2.3.2.120), did a pin reset, installed couple dhcp entries, did admin/reboot, and got back the factory reset page again where it detects my internet connection etc.
I gave up.
- Netduma-FraserApr 18, 2021NetDuma PartnerDid you install it using TFTP? If that doesn't work then the router must be faulty and I'd recommend getting a replacement if you can
- waver123Apr 18, 2021Aspirant
Yes I installed through tftp.
The duma inteface seems to be showing the correct version (2.3.2.120) so I think it installed properly.
But rebooting through gui again cause router to go through factory reset and lost everything.
My router is out of warranty, I ordered a r2 to replace this and will not recommend getting netgear router to anyone.
- Netduma-FraserApr 20, 2021NetDuma PartnerSorry to hear that, you can try unplugging the router for 24 hours as that can sometimes help with odd issues like this
