ficlet
May 18, 2023Tutor
XR500 not displaying traffic prioritization
Hey there! I'm running a XR500 and am having trouble getting my ping down/stable while gaming with Sea of Thieves. My friends report pings in the 50-60 range while I consistently am between 90-15...
Netduma-Fraser
May 19, 2023NetDuma Partner
Go to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, wait 2 minutes before accessing and see if it works then please.
ficlet
May 19, 2023Tutor
Thanks for the response! I tried upping the number of retries to 5 but there is still no change, it's just an endless loading wheel.
- Netduma-FraserMay 20, 2023NetDuma PartnerMake sure the web browser isn't forcing you to connect to the interface with HTTPS, force a HTTP connection instead and see if that works please
- ficletMay 20, 2023Tutor
Tried loading without forced HTTPS, no luck. It's still not loading.
- Netduma-FraserMay 21, 2023NetDuma PartnerMake an account on forum.netduma.com and let me know your username, then I can add you to the beta and see if that resolves it
