sev7nflow
Aug 04, 2022Apprentice
XR500 randomly drops internet throughout the day
Hello, My nighthawk netgear xr500 router keeps randomly dropping connection and all the lights turn off throughout the day. The only thing that fixes it is if I reset the power on the router. I looke...
Netduma-Liam
Aug 09, 2022NetDuma Partner
Since the upgrade, you may need to clear your browsers cache. It's possibly still trying to serve old cached data. If you could either do that, or try accessing the interface from an incognito window, that should work much better.
sev7nflow
Aug 09, 2022Apprentice
i just tried with incognito - i get this error
400 Bad Request
This server does not support the operation requested by your client.
- Netduma-FraserAug 09, 2022NetDuma Partner
- sev7nflowAug 09, 2022ApprenticeYes, I was utilizing router login.net, is there a difference between the two links?
- sev7nflowAug 09, 2022ApprenticeAlso if it’s any help, I can connect to the router fine - it takes me to the ping page and enter a admin // password screen. However I just can’t get past to the dashboard once I hit submit
- Netduma-FraserAug 09, 2022NetDuma PartnerThey would both allow you to access, other than that no difference but sometimes people are able to load better on one vs the other. Do a factory reset as you would need to do one anyway after TFTP is done and then see if it allows you to access properly
- sev7nflowAug 09, 2022ApprenticeStill the same issue… blank red screen after I input security answers and new password on incognito window
- Netduma-FraserAug 09, 2022NetDuma PartnerAfter doing a reset did it allow you to go through the setup wizard? You shouldn't need to do the forgotten password there
- sev7nflowAug 09, 2022ApprenticeAfter the reset, it goes to internet detection , then checks speed, then set up admin password and security answers. After I submit those, it does not proceed
- sev7nflowAug 09, 2022ApprenticeOk finally got it to go through after a number of Tfttp transfers and resets… will update if the router shuts off still
- sev7nflowAug 15, 2022Apprentice
so looks like the problem is back after 2-3 days of no drops. it is not happening as frequently as prior, but still occurs randomly
- Netduma-LiamAug 15, 2022NetDuma Partner
OK that's good, can you go through and setup the static IPs again, and change the DHCP range so the devices have IPs outside of this range. After that the drops should hopefully stop all together.
- sev7nflowAug 16, 2022Apprentice
Thanks... did this last night - so far so good.
Just trying to understand - what is the cause of the issue?
- Netduma-FraserAug 16, 2022NetDuma PartnerWe believe it's caused by DHCP renewing/changing the IP addresses of devices too soon/incorrectly. It is normal to do this but you shouldn't notice it usually. Netgear are aware and looking into it. This is the best workaround we have until they can implement a fix.
