gunengraver
May 15, 2024Aspirant
Re: XR500 randomly drops internet throughout the day
I can't be that it's 5/2024 and there is still no fix, what's gives netgear!
Netduma-Fraser
May 17, 2024NetDuma Partner
Set reserved IPs for your devices and that should help to resolve it
- gunengraverMay 17, 2024Aspirantwould that be for all devices or for wired only? i have at least 70 devices, I'd have to do that for each one? Netgear really dropping the ball here.
- FURRYe38May 17, 2024Guru - Experienced User
Can you give more details? What does randomly drops internet mean?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Is the top Internet LED turning AMBER when this happens?
- Netduma-FraserMay 17, 2024NetDuma PartnerIdeally yes as I believe it's to do with DHCP and we have seen it help for other people but that is a lot of devices so I can see why you wouldn't want to do that. Unfortunately it's the only solution I know of currently
I'd also change the DHCP IP address range as well.
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
