eli5539
Oct 02, 2022Tutor
XR500 Security
When I am attempting to log in I am asked 2 security questions. When I enter them I get a message that says these are incorrect. How can I correct this
- Oct 02, 2022Good advice above, I think your only move here is to go ahead and do a factory reset
michaelkenward
Oct 03, 2022Guru - Experienced User
eli5539 wrote:
Is there anyway I can back up my home network before doing a factory reset.
Yes if you can access the browser graphical user interface (GUI).
If you can't, then the answer is no.
Next time you set the thing up, first create a backup.
eli5539
Oct 03, 2022Tutor
Yes lesson learned. The security passwords should have worked and I know they are correct as I had them written down. Oh well thanks everyone for your help
- FURRYe38Oct 04, 2022Guru - Experienced User
Enjoy. 📡
