IJayJayI
Jan 31, 2019Apprentice
XR700 Keeps Kicking Offline
I have the XR700 Router with the CM1000 Cable Modem. Every time i try and play on Xbox live even just sitting in a party chat i keep getting kicked offline every few minutes. I have tried to factory...
IJayJayI
Feb 02, 2019Apprentice
Thanks for the reply, My Xbox is and has always had Instan On turned off. The router has and issue with MS IPv6, somehow it is incompatible in some form or another. The IPv6 keeps getting disconnected, and i do not know if it is Netgear's end, Microsoft's end, or both.
Shikwan68
Feb 07, 2019Star
Curious; is this problem completely non-existent with IPv6 disabled? Or is it less frequent?
